The right way to completely reset your Acer laptop to its factory settings is to use the Windows reset feature or Acers recovery partition. In Windows 10 or Windows 11 click the Start menu, Settings, then go to Update & Security > Recovery or System > Recovery, select Reset this PC, click Get started, choose Remove everything. This option deletes all your personal files, installed apps, accounts, and settings. It restores the laptop to its state. If Windows does not load, turn off your laptop and power it back on. Press Alt + F10 repeatedly when the Acer logo appears. This opens Acer's recovery environment. From there, select Troubleshoot, then factory reset acer. Choose Remove everything. The system will reinstall Windows and erase all data. Before you start,back up any files. This process permanently deletes everything on your Acer laptop.
