cerohep664 Posté(e) le 7 octobre Signaler Posté(e) le 7 octobre Explaining Data Science Projects During Interviews: A Practical Approach What a good project can do for you in a Data Science interview If it is important to know the data science techniques and write the right code, it is equally important to communicate your work well, reason well and show you can implement the concepts learnt into solving real-world problems. That's why good présentation of projects is also important. 7mentor Data Science can be used as an educational tool for students who have completed their training and wish to learn by undertaking projects, practicing exercises, and training. The most important next step once a project is done is to learn to showcase it confidently in interviews. Why does a Data Science Interview case study need project description? Whenever candidates list projects on their resume, interviewers have asked: - What was the project? - Where did you get the dataset? - How did you clean the data? - Which algorithms did you use? - Why did you use this model? - What challenges did you face? - How did you evaluate your model? - What was your final result? - What is it you want most? You don't need to learn all of these questions. But they'll demonstrate how you think. Talking to the interviewee through a real sample project One of the things that you will be able to get through as an interviewee is that you will be able to prove not only that you have got good technical skills but will also tell that you have got good communication skills and problem solving skills. Start With the Business Problem The best manner to explain a project will be to start with problem and never jump on Python libraries and algorithms. For example, instead of saying: First, I employed Pandas, NumPy, Scikit-lelearn and Random Forest. A stronger explanation would be: Known to Andromeda Forecast customer attrition in order to enable a company to identify customers at risk of churning and allow it to take proactive measures. This immediately gives the interviewer context. Once the objective is set, you can show how the data and the learning was used to solve it. Explain the Dataset Clearly After the goal is described, the dataset is descri Our strengths. You are asked only to describe your data, indicating what is available for analysis. Mention: - Number of records - Important features - Target variable - Data source - Type of data - Any important limitations For example: "The data set had customer data like the tenure, monthly charges, type of contract and mode of payment. Target variable was whether a customer had left the service." No need to figure out every single column unless interviewee requests it. Talk About Data Cleaning and Préparation Prepping the data is probably the most significant step of a Data Science project. Explain the steps you performed, such as: - Handling missing values - Removing duplicates - Correcting inconsistent values - Detecting outliers - Encoding categorical variables - Scaling numerical features - Selecting relevant features Don't: Just spit out techniques - contextualize them. Do: Explain why you're choosing to use the techniques. For example: "Some of the categorical variables had to be converted into quantities for the machine learning model to interpret it right." This demonstrates understanding rather than memorization. Explain Why You Selected the Model The interviewer may also ask: "Why did you decide on that model?" You should be prepared to discuss: - Why the algorithm was considered - Its advantages - Its limitations - How it performed - Why the final model was selected This is a perfect Opportunity for Sevenmentor Data Science course in pune Students to Merge what you have learned in classroom by Real-Time Project Based Decision making. Discuss Model Evaluation Acknowledge your model and let your model own up to this accuracy. Explain how you evaluated the model. Depending on the project, you might discuss: - Accuracy - Precision - Recall - F1-score - ROC-AUC - Mean Absolute Error - Mean Squared Error - Root Mean Squared Error
