Hi, there :yoo:
Sorry, that i write on english language. Just i don't know latvian language. :pray:
Okey, ladies. Go-go-go! :mjaso:
I présent to you my track Jog RR from 2003.
List of tuning: [Setup List]  :yoo::wrenchin:
- Aerox Block - Improved  (HOONIGAN edition)
- Cylinder– Stage6 Racing MK2
(HOONIGAN edition)
- Crankshaft– Malossi RHQ
- Bearings - SKF C4 Teflon
- Exhaust system– Yasuni C30 CARBON
- Carburator– Dell'Orto 21PHBG (102 jet)
- Air filter – Malossi E14
- Transmission - Full Malossi overrange kit
- Reed valves– Stage6 V-FORCE3 by tassinari
- Brake disque– Metarkit Oversize + Galfer brake
- Original CDI and stock ignition
- Gear shaft - Polini
- Coolant tank and radiator from Aerox
- Bosch electrical pump
- Killswitch
- Rev counter Stage6 + Koso régulator
- Motul MotoCOOL organic + coolant fluid
- Motul RBF600 brake fluid
Plan of rebuild:   :wrenchin:
  • Block from AEROX with disque brake (Installed
  • Electrical pump BOSCH  (Installed)
  • Speedometer Stage6 Tahometer  (Installed
  • Scooter needs for wiring rebuild (Installed
  • New LED LEXUS lamp and spoiler
  • Malossi Internal Rotor Ignition MHR TEAM
  • 2 -semislick tyres with R13 rims from Aerox - Dunlop TT93
  • 28mm or more carburator
  • Intake system from R&D
  • Also paintjob for NEW  Yamaha JogRR
P.S. Today scooter is a little bit adjusted and max speed  is +130 kilometer per hours
