JSP SCOOTER (tom67)
    81
  1. j'ai regardé http://www.google.fr/search?q=vilebrequin+stage+6+nitro&hl=fr&client=tablet-android-acer&source=lnms&tbm=isch&sa=X&ei=tlplUaf4DZOEhQecs4HYCA&ved=0CAkQ_AUoAQ&biw=1280&bih=752#biv=i%7C14%3Bd%7CopCwGKUznJMqKM%3A http://www.google.fr/search?q=vilebrequin+artek+k2+nitro&hl=fr&client=tablet-android-acer&biw=1280&bih=752&source=lnms&tbm=isch&sa=X&ei=61plUZz3EIXPhAfhjYD4Dw&ved=0CAYQ_AUoAQ#biv=i%7C0%3Bd%7CMK4WCF_lln_uPM%3A http://www.google.fr/search?hl=fr&client=tablet-android-acer&tbm=isch&ei=EltlUer9OMu7hAfViYCQDA&oq=vilebrequin+mxs+&gs_l=img.3...77004.77889.0.78724.5.5.0.0.0.0.143.503.4j1.5.0...0.0...1c.1j4.8.img.JnHK2RAOYWA&q=vilebrequin%20mxs&biw=1280&bih=752&sei=ZVtlUd_hFYuqhQee3YCoDw#biv=i%7C4%3Bd%7C4jISIvWnF6gTHM%3A http://www.google.fr/search?q=vilebrequin+polini+nitro&hl=fr&client=tablet-android-acer&source=lnms&tbm=isch&sa=X&ei=l1tlUbPuOsHDhAe69YC4Cw&ved=0CAkQ_AUoAQ&biw=1280&bih=752#biv=i%7C14%3Bd%7CEAimZT61cZn4QM%3A http://www.google.fr/search?q=vilebrequin+malossi&hl=fr&client=tablet-android-acer&source=lnms&tbm=isch&sa=X&ei=7ltlUcvaBsiBhAfP1oD4DQ&ved=0CAkQ_AUoAQ&biw=1280&bih=752#biv=i%7C5%3Bd%7CjW0O9JHk9u_lkM%3A http://www.google.fr/search?hl=fr&client=tablet-android-acer&tbm=isch&sa=1&ei=oFxlUdfqDpGYhQeLiYDwDQ&q=vilebrequin+doppler+endurance+nitro&oq=vilebrequin+doppler+endurance+nitro&gs_l=img.3..0i24.34748.37111.0.38115.6.2.0.4.4.0.134.253.0j2.2.0...0.0...1c.1j4.8.img.TmGwCM4qN3A&biw=1280&bih=752&sei=yVxlUc3WF5GBhQeXs4HIBA#biv=i%7C0%3Bd%7Cbic3K21d12_iPM%3A http://www.google.fr/search?q=vilebrequin+malossi&hl=fr&client=tablet-android-acer&source=lnms&tbm=isch&sa=X&ei=7ltlUcvaBsiBhAfP1oD4DQ&ved=0CAkQ_AUoAQ&biw=1280&bih=752#biv=i%7C6%3Bd%7CECGt6bVvBC0NiM%3A http://www.google.fr/search?hl=fr&client=tablet-android-acer&tbm=isch&sa=1&ei=oFxlUdfqDpGYhQeLiYDwDQ&q=vilebrequin+doppler+endurance+nitro&oq=vilebrequin+doppler+endurance+nitro&gs_l=img.3..0i24.34748.37111.0.38115.6.2.0.4.4.0.134.253.0j2.2.0...0.0...1c.1j4.8.img.TmGwCM4qN3A&biw=1280&bih=752&sei=yVxlUc3WF5GBhQeXs4HIBA#biv=i%7C14%3Bd%7CSwgLzVefVKFC-M%3A
  2. un de ces pot Giannelli!! lol jamais vue, il a peut être ete modifié aves une cartouche de gros cube lol.. pour ton polini evo, stage6 r1400 ou 1200, mhr team, yasuni c20-21, polini evo70 etc...
  3. tu a pris quel ressort de poussé alors?
  4. lol, met quand même 5 g
  5. ben essaie avec un gicleur plus'petit et des galets plus légers
  6. heu oubli je viens de relire, il faudrai plutot tester un 80 ou 85, serrer à fond elle broute = trop riche ce genre de symptôme vient du carburateur.. verifie aussi que le clips de l'aiguille est bien au 2em cran à partir du haut.
  7. ok alors prends soit le athena racing ou le metrakit sp3 si tu veux du performant, et pour 30 euros de plus tu as le bidalot et le mhr racing. avec vilebrequin barikit, carburateur 21 ou 24 ou +, pot yasuni r3, allumage mvt dd ou autre... sinon du fonte sport top noir ou metrakit hand made avec carburateur 21 pot yasini r2
  8. je prendrai celui là, athena racing 80 http://www.rrd-preparation.com/fr/kit-70-90cc-cylindre-piston-culasse-derbi-euro-3/2689-product-2689.html moins cher ici http://www.scootfast.net/store/moto/pieces-moteur/haut-moteur/derbi-euro-3/kit-athena-80cc-derbi-euro-3-racing.html avec un vilebrequin etc.... tu compte equiper comment le reste de la configuration?
  9. perso en mono segment je suis plus pour de l'alu, pour une meilleur dissipation thermique.. surtout en lc, l'alu est increvable
  10. si tu parles de vis de richesse, si, sur certain 12 gurnter elle est a tournevis plat, d'autres c'est une vis special et il faut un tournevis special. mais'il y en a toujours une.
  11. ? tu avais dit que tu avais mis les 5.5g et que sa ne marche toujours pas mieux
  12. test n gicleur de 95 et refait le réglage de la richesse ensuite
  13. c'est le top rose en 80 si on veut..
  14. tu as fait quoi?
  15. non le montage n'est pas compliqué, il y a des tutoriel pour tout bien faire, regarde dans mon tutoriel explication en signature partie 3. pour le pot tu peux avoir un bon pot pour moins cher, ccomme le yas z ou technigaz trek http://www.la-becanerie.com/scooter/echappement/pots-d-echappement/gilera-stalker/
  16. ce pot limitera la puissance le couple et la pointe, mais sa marchera quand même mieux qu'un origine
  17. pas trop pareil non, un 70 fonte aurra beaucoup de couple a mi régime aurra plus de force pour t'amener a 80 un 50 alu devras tourner plus haut dans les tours pour avoir la puissance mais au final avoir moins de force quand même. la pointe est un chouilla plus élevé avec un mono segment mais pas de beaucoup enfin tout depends du kit.
  18. oui premierement elle est déjà un peu'usee, et deuxièmement même neuve une malossi est plus large qu'une origine neuve, mais bon c'est pas une obligation après...
  19. oui mk2 avec carburateur 21, la yas R bridera pas tkt =(un chouilla on s'en fou) met une transmi 15-41 secondaire c'est ce qu'il'y a de mieux comme compromis. essaie de trouver le 21 Dell'Orto en black edition sont bien mieux, aiguille puis d'aiguille acces gicler sans enlever la cuve, démontage boisseau simplifié etc.. http://www.leboncoin.fr/equipement_moto/offres/alsace/occasions/?f=a&th=1&q=21+black+edition
  20. pas besoin d'une bielle plus longue pour ce kit?
  21. pourquoi avoir mis un gicleur de 85? ton problème 'est qu'il est trop riche donc rupte/broute a haut régime, tu as quel kit quel pot et quel carburateur et quel filtre à air? origine avec juste un pot ton gicleur doit être un 70 ou max 75.
  22. verifie la masse moteur, batterie et fusible pour ton vooyant d'huile.
  23. je mattrai un 70 dr et un pot yas R ou doppler s3r, tout le reste tu laisse, tu met juste une courroie neuve malossi et de bon réglages galets, ressorts et carburateur. kit, pot, courroie, galets et ressorts tu arrives a 300 euros
